How to mount purge in nostrils? (t/a)
Old 04-14-2004, 12:39 PM
01Sidewinder's Avatar
Question How to mount purge in nostrils? (t/a)
I have the dual purge kit. Now I need to know how to mount the end of the lines to my bumper to purge out the bottom nostrils. If anyone has pictures, that would help a bunch. Any ideas appreciated. Thanks.
Old 04-14-2004, 09:14 PM
dame's Avatar
i need to know the same thing (but the top nostrils if at all possible)
Old 04-14-2004, 09:35 PM
Bad30th's Avatar
Did mine in the bottom nostrils, N2o noid and purge valve located by hood latch under airbox :
More pics on my website.
Rob (Bad30th)
Old 04-14-2004, 10:29 PM
Scott 00TA's Avatar
Ditto, and i know it's possible I've seen it done.
Old 04-15-2004, 12:10 AM
y2kta's Avatar
Yea I just got it done on mine(top nostrils). I just ran 1/4 polyethylene tubing from the solenoid into a "T" fitting which then has dual 1/4 polyethylene tubing from both. Just finished installing 2 days ago so Im still working out the kinks. Main problem with running through nostrils is that running the line through the hood. I had a hole in the bottom of mine so I just pushed it through big enough for the tubing. Hopefully to have pics soon
