Brian Tooley Platinum springs
Old 12-14-2012, 08:12 AM
Asian LSX's Avatar
Default Brian Tooley Platinum springs
I was wondering if the .660 springs would be too much for a MS3 where the max lift is .603/.609. Or will they need shimed?
Old 12-14-2012, 08:30 AM
Super Moderator
Reckless's Avatar
Contact Brian and ask, he is easy to work with
Old 12-14-2012, 08:53 AM
Grr
Grr's Avatar
NO, they are just fine. perfect you might say
Old 12-14-2012, 10:49 AM
chevybayboy's Avatar
+1 really good guy
Old 12-14-2012, 11:39 AM
Turd Gen Guy
1nasty86's Avatar
As stated above... Brian is a good guy to deal with
Old 12-14-2012, 11:41 AM
Tainted's Avatar
if you are on stock rockers those springs will be to much
** allow me to correct myself. These are fine, its the max pressure that wouldnt be to good on stock rockers.
Old 12-14-2012, 01:53 PM
sic7camaro's Avatar
Why?next time explain your self
Old 12-14-2012, 02:00 PM
Asian LSX's Avatar
While I was at TFS we spintron tested those springs with a .600" lift cam and they actually performed the best. Springs with less open pressure had poor control, and springs with more open pressure actually pole vaulted the pushrods. The Platinum springs are only 380 lbs @ .600" lift which seems to be perfect for use with stock rockers, but they have great seat pressure to prevent valve bounce on the seat.
I emailed Brian and he replied back with this. Very good guy to deal with and email response was very fast which suprised me.
Old 12-14-2012, 02:16 PM
Tainted's Avatar
Because more pressure isnt always a good thing. The platinums are ok, I keep mixing them up with his max pressure spring which is to much for a stock rocker. Hows that?
Also you can read brians response to the OP
Old 12-14-2012, 02:20 PM
Grr
Grr's Avatar
that is a complete crock of ****
Old 12-14-2012, 02:49 PM
Super Hulk Smash
JakeFusion's Avatar
Platinums work great with stock rockers. Just make sure the rest of the valvetrain is optimized. Don't go throwing LSK lobed cams in there with LS7 lifters and you'll be fine.
Old 12-14-2012, 03:10 PM
Tainted's Avatar
Yup I caught that myself see above post where I corrrected myself by mixing up the platinums and the max pressure kit. K thx
Old 12-14-2012, 03:32 PM
Grr
Grr's Avatar
good, dont do it again!
Old 12-14-2012, 04:20 PM
Tainted's Avatar
Trust me its a bitch looking at 10 different of pages of springs
Old 12-14-2012, 11:22 PM
???? Really
Old 12-15-2012, 10:16 AM
Brian Tooley Racing's Avatar
Originally Posted by chevybayboy
+1 really good guy
Thanks a TON for the kind words fellas! It means a lot! Let me know if I can be of service!
Old 09-22-2014, 03:41 PM
lsexpress's Avatar
is this really a must have for high lift
Old 09-22-2014, 03:58 PM
Define high lift?
You need at least LS2, LS3 or LS6 springs to run up to .560" lift.
If you want to run over .600" lift then you should consider dual springs.
Quick Reply: Brian Tooley Platinum springs
