68 camaro 5.3 single turbo swap, what manifolds?
Old 12-14-2012, 11:09 AM
Boosted68's Avatar
Default 68 camaro 5.3 single turbo swap, what manifolds?
First off let me say I'm new to the sight, and new to Ls motors. I recently pulled the 454 out of my 68 camaro and picked up a 5.3. I'm trying to put a single turbo set up on but don't know what stock manifolds will work. I know theirs a lot of info on it but it seems most of them are twin turbos. I'm not using a/c or power steering. I'm using hooker swap plates and stock clamshells for stock engine placement. Also I'm going to use the dirty dingo alt bracket. Any help is appreciated!
Old 12-14-2012, 03:38 PM
LS1NOVA's Avatar
If you search my user name and look at my Nova build thread you will see one option. Another option is the regular truck manifolds cut down and vbanded. They will work down and forward with a few tricks.
Old 12-14-2012, 06:29 PM
Blackpanther99's Avatar
Truck manifolds should work great!
Old 12-14-2012, 07:16 PM
chevellepowered's Avatar
i will be doing a 68 camaro soon ... if you have money the ebay turbo manifolds are nice.. for looks .. but on budget the truck manifolds work great ..
Old 12-15-2012, 08:53 AM
Boosted68's Avatar
Yeah I'm trying to stay on budget. I came across a guy who has a homemade hot side kit that was for a truck. It has one ls4 manifold on the passenger and a truck manifold on the driver side. He also has a spare fbody manifold I could get. I know I would have to cut and re-weld a couple spots but for $300 is it worth grabbing?
Old 12-15-2012, 10:24 AM
LS1NOVA's Avatar
Dont waste your money on a kit made for a truck, its not going to fit. An LS4 is pretty tight on the frame on the right unless you space up the engine higher or mod the frame. Id recommend a cut down truck manifold so the outlet comes straight forward between the frame and water pump. On the left, a Trailbalzer right manifold flipped forward and down works best because its a little thinner through the middle and offers a little more room around the steering box than a regular truck manifold. My left manifold has had the flange angle milled. PM me your email and Ill send you a picture of a set I just did for a guy.
Old 12-16-2012, 01:15 PM
Boosted68's Avatar
Pm sent.
Old 12-16-2012, 08:48 PM
LS1NOVA's Avatar
Here are the pictures.
The angle is a little decieving but once you get the vband on and turn the bend down it clears the heater pipes fine.
Hear is one I did using stainless weld els for manifolds. It should give you some ideas on routing etc.
Old 12-17-2012, 07:46 PM
Boosted68's Avatar
Thanks for the pics. I dropped the motor in today and tomorrow I'm going to start routing and fitting some pieces together. I should be able to figure it out by what you have told me thank you I appreciate it.
Old 12-18-2012, 08:16 AM
heinzfiftyseven's Avatar
I like the second one. Very nice....
Old 12-24-2012, 07:19 PM
windsma's Avatar
Needed this pic.
http://i1025.photobucket.com/albums/...pscc2cc9a0.jpg
Thank you!
Not many pics of Vette accessories with the first gen subframe.
Old 03-14-2013, 10:52 AM
Slim80's Avatar
Default Single turbo
Looks awesome. Do you have any pictures of how the passenger side manifold connected to the turbo? Or pictures of the merge you did. Thanks in advance.
Quick Reply: 68 camaro 5.3 single turbo swap, what manifolds?
