Bought a built LS1 longblock - I need advice for my build!
Old 12-14-2012, 08:00 PM
KarlSpackler's Avatar
Default Bought a built LS1 longblock - I need advice for my build!
Hello gents. 1st post but long time lurker but I am needing advice so I decided to sign up and become apart of the madness. I am a long time member on many BMW forums.
Anyway, I am swapping a LS1 into my BMW. I am familiar with swaps but not the LS1 motor. So when a local shop offered a long block LS1 with 6.0 Patriot heads I jumped at it not knowing what I was really buying (money was burning a hole )
The motor was boosted with 6psi through a supercharger for only 6xxx miles and was in great running condition but I was made to believe I could use this motor for my N/A build.
What are all of your thoughts? Below is the build sheet. They gave me this info when I bought it. It is a LS1 out of a 2003 WS-6.
Patriot LQ9 6.0 - STAGE 2 (2.055/1.57/72cc)
GM MLS Head Gaskets
Felpro Head Bolts
SPEED INC LSx CUSTOM SC CAM 222 /228 .566 .571 LSA
114
Comp Chrome moly Pushrods
GM Crank Bolt & Seal
ARP LS1 12 POINT HEAD STUDS
GM12558573 GM LS1 HEADER GASKETS PAIR
NGKTR6 NGK COPPER PLUGS
ALSO, this was on the tune sheet:
Dyno Tune 98-08 LSx
Forced Induction
motor stock short block
injectors 60#
stat - 160
cam 222 /228 .566 .571 LSA 114
rev limiter
exhaust - off road
gear - 3.73
MAF...STOCK !
My questions are, from my searching people only run the big 72cc LQ9 Patriot heads with F/I. There is also a "custom SC cam".
It seems like a really high quality motor build and it is verified at only 36xxx miles and I would really like to use it BUT I dont know how easily I can.
My goals are 400-420rwhp through a T56 that has a daily driven feel.
So
Can I use it as is? Need different cams? Just sell it and buy a LS2???
Thanks for your time to read this all and your input
James
Old 12-14-2012, 08:08 PM
For reference, this is the boat the motor is going it (98 e38 )
Any my previous 89 E30 M3
Old 12-14-2012, 11:09 PM
GarrettM's Avatar
That motor will meet your goals as it sits! No need to change anything for your goals BUT if you felt you just had to... I would call any one of our great sponsers and discuss for you a purpose built cam. A cam designed for supercharged engines has different valve events than one built for N/A. While the cam you have is more than capable of meeting your goals a properly specced cam based off your your specific build could pic up a few ponies and also improve street manners.
Old 12-14-2012, 11:58 PM
badazz81z28's Avatar
What are LQ9 heads? 317s?
All you need is a better cam for your combo and it should be GTG!
Old 12-15-2012, 12:47 AM
GarrettM's Avatar
Yes, Patriots 6.0 heads are 317s I believe.
Old 12-15-2012, 09:50 AM
So who can suggest some cams for me?
Old 12-15-2012, 10:38 AM
ejbta2's Avatar
Texas Speed will help you with a cam selection, they are great people to deal with.
GarrettM's Avatar
Contact Patrick G on here for a custom spec, or Texas Speed, Tick Performance, Futral, Thunder Racing and several others. My recommendation would one of the first two.
Old 12-15-2012, 10:42 AM
GarrettM's Avatar
Just keep in mind though you will be fine with the setup you have. While not absolutley necessary when doing tge cam swap i would go agead and swap valve springs. These parts have a certain lifespan that can be shortned with an aggressive cam working hard. The springs you have now may be fine but I wouldnt take their word for the number of miles on them. Replace them with the cam for peace of mind and security.
Old 12-15-2012, 11:19 AM
Super Hulk Smash
JakeFusion's Avatar
If you want more torque, you'll need a custom spec cam to get the dynamic compression up with those heads. Once you verify the chamber size and piston dish (if any) then it'll be easier to spec a cam to get the cranking compression up. That'll get the torque up and make that thing move. PatG costs $25 to get a custom spec through, but probably worth it. I'd also talk to Martin @ Tick Performance and Ed Curtis at FlowTech Induction. They'll probably all spec you something pretty similar just with different lobe profiles.
But I agree, the way it sits, it'd probably be good for 400+rwhp.
Old 12-15-2012, 01:42 PM
GarrettM's Avatar
^^ all great recomendations for guys to spec you a cam. But like we previously stated your setup is good to go. Don't need to change anything unless you just want to.
Old 12-15-2012, 01:50 PM
Sierra Speed Shop's Avatar
That cam is nice and mild, and will have great street manners, but the heads and cam are not ideal for N/A application. To get the most out of your combination, you can upgrade the camshaft, and heads (smaller combustion chamber for more compression).
If you have any questions, feel free to call me! We're here to help!
(916) 757-2326
-Kyle Higgins
Old 12-15-2012, 05:18 PM
Thanks a ton guys! I really appreciate the advice.
I am going to stick it in as is. Tune it and see what it says I am making on the dyno and then go from there!!!
Old 12-15-2012, 05:30 PM
Gunslinger09's Avatar
I would just sell the heads you have now and pickup some ported 243's and call it a day. I think even the cam thats in it now will make over 400 HP at the tires if you get the compression up over 10:1.
Old 12-15-2012, 11:34 PM
k_cash1432's Avatar
2003 WS-6? Hum i hope you fat fingered that one...
Old 12-16-2012, 03:07 AM
GarrettM's Avatar
Lol I just noticed that
Old 12-16-2012, 09:34 AM
wildcamaro's Avatar
Yea you could prob sell those heads, get a set of ported 243 heads and still have some extra money for a retune if you play your cards right. The patriot heads you have will work, but NA LS engines live compression especially with an aftermarket cam.
Old 12-16-2012, 11:31 AM
yeah, 2002 sorry.
This will be the plan. I am going to get it in as is and go from there
Quick Reply: Bought a built LS1 longblock - I need advice for my build!
