Boosted 5.3 guys drop in.
Old 12-16-2012, 09:40 AM
cbr600rx7's Avatar
Default Boosted 5.3 guys drop in.
Just wondering what kind of boost everyone is running on their 5.3s. We all know they have a reputation for being tuff little SOB’s but wanted to see some real numbers and durability.
List your vehicle, engine mileage, miles since boost, blower/turbo set up and details about boost levels.
05 Z71 crew cab, 97,000 miles, 30K on Eaton M112, peak boost at a safe 8lbs.
Truck also made 386 torque and 347 whp on a mustang dyno. Figuring 12% change on a dyno jet that works out to about 432tq and 396whp
Old 12-16-2012, 05:33 PM
a4ls2goat's Avatar
On 16psi on a eBay gt45 my car made almost 600whp through an unlocked converter on a 4.8 which is the same
Old 12-16-2012, 07:57 PM
Talon77's Avatar
My stock bottom end 5.3 with ls9 gaskets, head studs and a cam makes 787hp at 21lbs of boost. It's on E85. Not many miles on the turbo setup but the shortblock had 31k on it when the heads came off and new gaskets/studs went in.
They are tough little engines!
Old 12-16-2012, 10:41 PM
CameronVic's Avatar
Mine let go at 22.5 psi and 18* with E85, and 120*ish IATs. Haven't gotten it out and apart yet, but will soon. Motor ha 181,000+ miles on it.
Old 12-16-2012, 11:13 PM
91sonomast's Avatar
What kind of psi is safe to run on 91 octane? I know guys with E85 can push well into the 20's, but we don't have E85 readily available. I do have methanol racing fuel readily available though, for a water/meth setup.
Old 12-17-2012, 07:52 PM
cbr600rx7's Avatar
I would think spraying water/meth would get you close to E85 depending on the mixture. But keep in mind E85 is somthing like 105-108 octane. How many of you guys are on stock bottom ends.
Old 12-19-2012, 10:10 PM
cbr600rx7's Avatar
Some good numbers for stock bottom ends. Any death stories out there?
Old 12-19-2012, 10:35 PM
T76s10's Avatar
96 s10, unknown mileage, 2000 5.3, got her up to 18lbs on an on3 76mm. thought i heard clunking so i took the motor apart and everything was as good as day 1. that was on 93 octane no meth.
Old 12-20-2012, 02:20 PM
TX RED's Avatar
06 5.3 arp studs 243 heads custom cam ls6 intake 548hp on 13.5 psi mpt70 turbo e85
Old 12-21-2012, 07:13 PM
Bumper Dragin Bird's Avatar
What kind of cams are u guys running? I have a stock 5.3 that im putting 317s on with a ls6 intake and a single 76mm. Any suggestions for the cam. Thanks
Old 12-21-2012, 09:38 PM
carlsonauto's Avatar
2004 lq4 (I know not a 5.3) engine had 144k when installed. Completely stock except cam, springs and cometic head gaskets. Ran hard on E85 and 70mm turbo at 19-20 lbs. Turbo started leaking oil into the charge air and caused detonation (Im assuming) and lifted #5 ring lands and bent #5 rod. Im sure it did more but I didnt disassemble any further at that point. It made a 4700lb 4x4 truck a handful and fun while it lasted.
Old 12-21-2012, 09:49 PM
TX RED's Avatar
I would go with 243 heads....with 317 8.5cr would be a dog out of boost
Old 12-22-2012, 08:32 AM
got-a-ls1's Avatar
i was running 18-19psi with a pt7675 and went 109mph in the 1/8th mile (3800+lbs) spinning through each gear. the 109mph run i hit and held the limiter in 3rd gear before the first timing box til the end, so atleast 60-70 feet before the end of the track was on the limiter. i run 16° of timing and meth injection on 91.
i ended up killing the motor with a 3-2 shift and it saw ~8500 rpm. ooops. was running stock pushrods and it didnt bend them, no valve contact.. just killed the rod bearings, still drove it home with 10 psi oil pressure. id say theyre tough! mine was starting to chew the bearings prior by seeing a bunch of junk in the filters but i beat the hell out of it for 6k miles... and admittedly i ran it low on oil a couple times under acceleration it uncovered the pickup tube
Old 12-22-2012, 08:50 AM
Blackpanther99's Avatar
https://ls1tech.com/forums/vehicle-c...silverado.html
Check my thread out, you can get an idea if what to do in your project . Extended cab 06 Silverado 5.3 with a garret internal 76mm turbo. Truck has no lag. Only issue is gears, stall and better fuel system to get better ET times
Old 12-22-2012, 09:28 AM
TheLS1Lover's Avatar
Keep the stock heads or go with some 243s. With the 317s it will be terrible until you build some boost.
Old 12-24-2012, 06:34 PM
ok...what kind of cam should i run?
Old 12-24-2012, 06:55 PM
a4ls2goat's Avatar
2008 4.8 with a eBay gt45..
See Sig
Old 12-24-2012, 07:09 PM
Hondo78's Avatar
Default What cam should I use
Hot rod did a test with a 5.3 and LS6 Cam and a EWay Turbo made 594HP
http://www.hotrod.com/techarticles/e...2/viewall.html
Goin fast on the cheap..er
Quick Reply: Boosted 5.3 guys drop in.
