Need help with skinnies and wheel spacers
Old 12-17-2012, 12:08 AM
wesam's Avatar
Default Need help with skinnies and wheel spacers
I ordered skinnies for my 2001 T/A with new thick brake rotors
when i tried to fix them i noticed the rim will hit the brake calipers front and rear it seems the grinding will not work as i need extra 3mm space so i need to order wheel spacers
those the wheels i ordered
http://www.summitracing.com/parts/SUM-571-5862PS
http://www.summitracing.com/parts/SUM-571-5461PS
I will fix MT ET 15/50/275 in the rear
any help with wheel spacer part number that will not make the tire touch the fenders
thanks in advance
Wesam
Old 12-24-2012, 05:11 AM
IllusionalTA's Avatar
Those are similar to the WEld's.. you will have to grind on the rear... a 5/16 wheel spacer in the front is all you need for them to clear...
Old 12-24-2012, 05:25 AM
Captain Double Post
BOBS99SS's Avatar
I had to gind a lil more when i did brake pads,you also want to run longer studs ,
Quick Reply: Need help with skinnies and wheel spacers
