WTT full race setup.10sec- 95 Z28, BBC, enclosed trailer!!
Year: 1995
Make: Chevrolet
Model: Camaro
Price: $30000
Mileage: 175
Private or Dealer Listing: Private Listing
Location (State): LA
Color: White
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has other engine
2012 enclosed trailer w/ race 2 package, shelves, winch, honda quiet generator
Motor is fresh 2- 1/8 mile passes / 6.88 and 6.90
3-1/4 mile passes / 10.73, 10.77, 10.75
125 street driven miles...
Nitrous kit still in package never installed, all motor passes on a light 3200 t-brake hit.
1995 Z28 DRAG/STREET CAR W/496BBC
ENGINE: 496 BBC, 4 BOLT MAIN,60 over,Eagle 4340 4.250 stroke crank, eagle H beam rods, 13 to 1 SRP pistons, J-E plasma moly rings, lunati roller cam, 680/685 268/272 @ 0.50, lunati roller lifters, cloyes timing chain, square port heads (#188) w/new stainless steel valves, roller springs 235 lbs closed, 720 lbs open, port matching & blending, harland sharp roller rockers, jomar stud girdle, edelbrock 454R intake, msd distributor, msd 6al ignition box, msd 3-step, msd rpm module selector, msd timing retard comp., msd plug wires, holley black pump w/regulator, Power systems 1050 Pro IV dominator (NO2) carb w/removable venturis, hooker headers, 3 in exhaust, 3 in magnaflow stainless steel mufflers, NANO 3000 psi. NO2 assist,PERFORMER edelbrock NO2 plate system(never installed). / TRANSMISSION: Turbo 400, J-W Ultra Bell, J-W pro trans brake valve body, B & M deep trans pan, TCI 8in (5200 stall), hardened input shaft, B & M pro stick shifter REAR END: Moser fab 9,9 in ford housing (built for F body), moser nodular center section, daytona pinion support, 1350 drive yolk, moser spool, moser 35 spline axles with 5/8 wheel studs, moser 4:10 gears, rear disc brakes CHASSIS: AJE round tube K-member, spohn round tube torque arm, spohn trans cross member and subframe connectors, hotchkiss panhard bar, 6 point roll bar WHEELS: weld 15 x 10 with 11.5 x 28 et drag radials tires, JEGS 15 x 4 frontrunners with 165-15 FEATURES: battery relocated to rear, glasstek 4 in cowl hood, power steering, power brakes, power windows, leather interior
email-jerrycolwart@yahoo.com for pics or questions !!
