Pontiac GTO 2004-2006 The Modern Goat
Strut replacement
Old 12-19-2012, 02:31 AM
F8L GT's Avatar
Default Strut replacement
Hey guys, just wondering if any of you knew roughly how long it takes to replace the struts, front and rear on a GTO.
Old 12-19-2012, 02:35 AM
birner88's Avatar
Idk couple hours tops
Old 12-19-2012, 09:10 AM
steamwalker's Avatar
Couple of hours seems about right as long as you have all the proper tools.
Old 12-19-2012, 09:32 AM
F8L GT's Avatar
I'll also be replacing the bushing do maybe I'll figure 3-4 hours
Old 12-19-2012, 12:37 PM
409CISecondGen's Avatar
I would plan a whole day at least. All Data says 6.2 hours to overhaul the front and 7.8 to overhaul the rear. That is replacing bushings and struts/springs.
Old 12-19-2012, 12:44 PM
F8L GT's Avatar
Thank you. That's the answer I was looking to get. I have someone who has adjustable struts and springs that wants them installed along with the better bushings
Old 12-20-2012, 08:20 AM
Seriously depends on what bushings you are talking about. There are dozens on this car. If you are just talking about strut mounts, that won't add to your time.
Old 12-20-2012, 10:24 AM
F8L GT's Avatar
http://www.energysuspensionparts.com...p?prod=3.18134
This is the kit he wants done
Old 12-20-2012, 10:27 AM
F8L GT's Avatar
Along with this
http://www.kollarracingproducts.com/...ac-GTO-/Detail
Old 12-20-2012, 03:45 PM
Death{AW}'s Avatar
if you have access to impact I did front and back in 5hrs total with most of the bushings and endlinks.
Old 12-20-2012, 05:46 PM
You'll probably spend more time on the control arm bushings and swaybar bushings than everything else combined.
Old 12-20-2012, 05:50 PM
Robofuzz's Avatar
Let me just say that the rear lower control arm bushings are a major PAIN IN THE *** to get out. I spent a great deal of time on my back with the car and rear cradle on jackstands. Finally had to use a propane torch to get those bastards out.
Old 12-20-2012, 07:16 PM
svede1212's Avatar
I published about using a torch and homemade tool about 5 years ago. At the time the conventional wisdom was that you had to have a Pedders special tool to do it easily. After I figured out the first side (I did inner, outer and subframe at the same time) the second set came out in under an hour.
Old 12-20-2012, 10:46 PM
Robofuzz's Avatar
Yes - your guide was invaluable. But I still had trouble getting them out.
Quick Reply: Strut replacement
