need info on tach signal wire and autometer tach hookup
I am having trouble finding tach signal. Harness and ecu from 02 ss in a rock buggy, ive searched and only could find the tach wire from ecu but my ecu is tucked away and im not taking my entire dash and ecu out to hook up one wire if i dont have to.so my question is what wire on the passenger coil pack plug is the tach wire? I also hqve a autometer sportcomp2 tach and it dont have the standard 4cyl switch option. You hqve to cut looped wires to calibrate for 4cyl mode. But there is a 2 pulse 4cyl mode and a 1pulse 4cyl mode. What pulse do i need?
My tach has a blue and brown wire you cut to make it 6cyl 4cyl 1pulse or 4cyl 2pulse. I piggybacked every wire on the coilpack plug and nothing. Only when it was hooked to the green or the red the tach would say its idleing at 100 and when id rev it to at least 4500 it only goes to 350-400 on tach
Couldnt get tach to read right so i ended up pulling wire to pcm pin10 white wire and works now. So i guess the coilpack harness wires are not enough for tach to read from.
Good job doing it the right way
