is it to big
Old 12-19-2012, 05:58 PM
six095ta's Avatar
Default is it to big
Going from a 6.0 s475 with a 238/242 113 to a 5.3 s475 and I have two cams to pick ls6 or 232/234 112. What's you choice
Old 12-19-2012, 07:11 PM
jridenour31's Avatar
232/234, assuming a 96mm hotside
Old 12-19-2012, 07:15 PM
z28hustle's Avatar
i know this has nothing to do with the original question but why are you going down in displacement?
Old 12-19-2012, 09:51 PM
six095ta's Avatar
It is a 96 hotside. The 6.0 is getting built over the winter and I dont want the car to be down that long
Old 12-19-2012, 09:55 PM
LS1NOVA's Avatar
Big one.
Old 12-19-2012, 09:56 PM
I8UR4RD's Avatar
Too *
Old 12-20-2012, 12:53 AM
LilJohn's Avatar
Be interesting to see how that much overlap works with the smaller motor with the 96/1.32 hotside....
Anybody know how many degrees a tooth is worth on the LS timing set?
Install it on a 107-108 intake centerline and let it eat.
Hell 105-106 if itll clear on the piston to valve.
Old 12-20-2012, 06:13 AM
9sectruck's Avatar
8degs per tooth on cam gear and 16 per crank gear,
45 teeth on the cam gear
Old 12-20-2012, 09:41 AM
LilJohn's Avatar
Hmmm 112+8....lol....
Quick Reply: is it to big
