rocker bearings
rocker bearings
so if i had several rockers bust on me and spill bearings all over the place; does that mean my motor may blow? ill change oil before i start it again. doing trunion upgrade and swapping to correct valve seals. just hope this did not do permanent damage to my motor.
They really can't go anywhere. Some may have fallen in near the lifters, you should be able to get a magnet in there. The rest will be in the head or in the pan. They are too big to get sucked through the pick-up. You should be fine.
cool. thanks for the info guys. i can feel alittle better now. waiting for ups than its off to swap all seals, and trunion upgrad on rockers. ima prolly pull the shims, and hopefully i didnt bend any pushrods.
