A body th400??
Thanks for the replies guys. I just wanted to make sure I wasn't overlooking something. Makes sense trying to get best mileage. I have a fresh 400 that I will run unless I run across someone with a 4l60 or 80 that wants to trade.
If drag racing the th400 would be much better. Cheaper to build, stronger, and not such a steep drop between 1st and second. If you ever want an overdrive, bolt up a gear vendor and be done. Pricey, but bulletproof
