setting up 6.0 vette to reach the maximum HP
i have corvette 2005 LS2 6.0L
it has cold air intake and L/T headers with zo6 transmission with cluch and ECU.
i am planning to maximes the highest HP with my car the driveability is not an issue for me
i will install texas speed tsunami cam kit
melling oil pump
spark plugs ngk tr5
but i have some questions, do i need water pump, fuel pump or injectors ?
if i do then what is the best suggestion for me?
what LSA shell i need to take for the camshaft ?
what good size for push rod or spring valve ?
any thing do i need to change instead of this camshaft is so what other good camshaft.
melling oil pump
spark plugs ngk tr5
This will increase your power by at least 150 hp!
http://kalecoauto.com/index.php?main...products_id=36
But you have to use it with this
http://kalecoauto.com/index.php?main...products_id=37
And since its hot over there in the sandbox you'll need this so you won't blow it up!
http://kalecoauto.com/index.php?main...products_id=43
Keep us posted with your progress cause I'm subscribing AGAIN!
didnt understand
__________________
01 Ws6,m6, ASC#618 of 1583,AES built forged 416,ArP'd,Morels,LPE Ls3 heads 12-1 comp,FAST 102 by chris1313,N/W 102 Tb,Racetronix F/P,65lb inj,C5r T/C, LsR 243/259 .624 114+3,P/B 10% Ud,Kooks 2" headers,Kooks yp,Dmh dual c/o's,COMPLETE UMI suspension,SLP Torque arm,viperized T56 by wrencher,Textrellia,Moser 9" spooled w/4.11's & 35 spline axles, Koni 4th Gen's,BMR springs,Sjm abs delete,magna flow CB, StraightLine Tuned!
__________________
You'll see the most gains depending on your head choice.. Is money an option for you? Money is the only limiting factor
