General LSX Automobile Discussion Non-technical LSX related topics.
408 need upgrade advice
Old 12-21-2012, 11:05 PM
MASS seller approved
smok'nZ's Avatar
Default 408 need upgrade advice
408-patriot stage III heads,texas giant cam, fast 102/102, 85mm maf 98mm lid,1 7/8" LT's w/3" true duals,tubular k member and A arms, sfc's, lca's, stock 10 bolt (i know its on borrowed time) stock 3.23 gear 28/10.5 slicks th400 with 4400 stall flashes 46-4800
Think thats all need to be faster n/a before I spray the car
Car only cuts 1.6 60ft
Mods im thinking about
Lca relocation brackets
Girdle+axles
Weight reduction (seats,airbag,door bars,light weight carpet no padding,front and rear bumper support
Old 12-21-2012, 11:08 PM
smok'nZ's Avatar
Also have rear qa1's about to go on and thinking of speed density 104lid straight to tb
Old 12-22-2012, 09:05 AM
Mazzenger's Avatar
Different pulley?
Old 12-22-2012, 09:50 AM
A.R. Shale Targa's Avatar
In addition to the weight loss I'd go S60 or 12 bolt and 3.73 would be a good
juice gear, but you may want to tighten up the converter 800-1000 rpms for
you to maximize with the spray.
Old 12-22-2012, 01:43 PM
zracer323's Avatar
If I were you I would spend the money on a 9". At very least get the girdle.
Old 12-22-2012, 08:30 PM
dnkynrbk's Avatar
See my car in my sig its a 408 with patriot heads custom cam. and runs 9.30s on spray.
Old 12-24-2012, 01:11 PM
smok'nZ's Avatar
Girdle will happen before I go.to the track again
Different pulley? A 25% underdrive I dont want one on my car didnt help any on my old motor
Old 12-27-2012, 09:46 AM
dnkynrbk's Avatar
pully isnt going to help that much. I have tried a10% and a 25% the 10 performed better.
Quick Reply: 408 need upgrade advice
