F-Body Coilovers
F-Body Coilovers
Been thinking about this lately. The 4th Gen F-Car LT and LS platform has been around for about 20 years now.... Why don't we have an affordable, "Box Set" ready to bolt in set of coilovers for $800-$1200?
Why doesn't Koni offer this? Our only other option is KW V3's and those are ungodly expensive. Most of the F-car world has shallow pockets, so I think the $800-$1200 price range is accurate.
I've seen some QA1 "Street" sets, and seen some people mix and match between a custom coil and the QA1 shocks, but it all just seems like a hassle.
What gives? I mean, I want a decent set that handles good. But I want my car a bit lower than most of the good springs out there. I know some will argue that a correct height is there for a reason with spring rates and all.
LS1TECH Sponsor
Because they'd be junk.... That's what all $800-1200 coil-over tend to be. We know Koni Sports rock it, and they are dampers only and cost that. Koni has had plans forever for the STR.T's for this car, but never went through with building them. If they had, they'd still have been around $600 based on where the STR.T's line up with Sports on an S197 Mustang (where they are both made).
QA1 shocks are one of the examples of not a very good shock you are paying for the bling. The price difference between those and KW's in in the fact KW's are really good, really well performing dampers like a Koni... with a lifetime warranty, a gas-charge, stainless steel bodies, etc...
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
LS1TECH Sponsor
On the front of what? Koni's will work.. but you have to modify the shock to install a sleeve and that technically kills the warranty.
Remember that "coil-overs" are both the shock and the spring setup... but too many people just think of them as adjustable for springs and that all the shocks are the same. They... are.... not...
__________________
LS1TECH Sponsor
Can't answer that.... Depends on few things. What coil-overs????????? What use? How important is ride height adjustment vs. really good control?
That question is far to broad, it's like asking are faster cars better? They can be... they might suck to drive.
__________________
LS1TECH Sponsor
Way more than KW's... if they are adjustable. And Penske doesn't sell ready to go shocks, it's up to the seller or buyer to determine valving and that's the hard part. And no lifetime warranty, etc.
Also, I've whipped up on smaller guys in lighter cars (one notable case where the other guy and his car were 300 pounds less than me in my car) with triple Penske's to win National Championships.... and it's not like those guys sucked, each has no fewer than 3 National Championships of their own in other classes.
__________________
adjustable rear coil springs
Has anyone used these before, it looks like a nice setup for cheaper adjustable rear coil and shock setup. Then you can just buy the front coilovers for real cheap...http://www.wolferacecraft.com/detail.aspx?ID=820
What do you think of the Bilstein/Eibach Shock and Spring set that SLP sells?? See link below if not familiar.
http://www.slponline.com/view_product_site.asp?P=70002
I have heard that you are the go to guy for making these cars corner... is that set a reasonable place to start?? (obviously buying all the other suspensions goodies, sways, SFC, LCA, PHB etc...)
Thanks!
LS1TECH Sponsor
__________________
LS1TECH Sponsor
I was really hoping to find a reasonable set of coilovers for my 94 Trans that I am setting up as a beginner autoX car.
Thanks!
Thanks!
I also do not think some of the things on your obvious list are things you should start with either. LCA's and SFC's are not required to make the car handle better. In some cased the wrong LCA's make it worse, same for some types of torque arms.
__________________
Personally, I'm not going to getting under the car all the time to change the settings on the shocks trying to constantly tweak it. I tend to get to a spot that works and then leave it alone. But that's just me. More power to the guys that put forth that effort, they're likely faster than me.
The OP wanted to know about a true coilover for the car, there they are. About 1100 for the pair and they're quality coilovers.
