Complete TURBO KIT
Complete TURBO KIT
Category: Engine - Power Adders
Price: $1
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): IL
Item Condition: Used
Engine: LT1/LT4
LS Engine?: Non-LS Part
Only need injectors and a tune to complete the kit. Everything is here to complete the install and you cant ask for more than that.
$2700 SHIPPED FIRM
3" in/out on the inter cooler, Intercooler is mounted in the standard location in the front bumper support. Also, this kit was built around me BMR tubular K-frame. I cant NOT tell you 100% if it will work with a stock frame. But any tube frame it will work with. Radiator was a stock lt1 with aftermarket puller fans that worked great. I would rather have used a pusher fan but these are what were laying around for usage. Radiator must stand straight up for this turbo to fit in the engine compartment.
The intake/cold side plumbing is 3". Turbo inlet and outlet are 4". All hose clamps, hoses, piping is complete with this kit. Even the turbo has less than 400 miles on it with about 20 passes on it. Very good condition with 0 issues.
This kit made 850hp on motor on pump gas with 18lbs of boost and is very reliable and can be driven everyday. It was on a 383 with AI200 heads and also had AFR 210 heads with a 4l60e and 3.23 gear on a 28" tire. Ran 9.2x at 144 in a 3300-3350 lb car. So if your car with you in it is less than 3100lb you will have a 8 sec car all day long and still be able to drive it everywhere and/or turn up the boost.
WILL take a $500 deposit up front but must be paid off by FEB 1st. Then I will ship the product. I will keep your deposit if you back out of payment or stop paying or dont pay by Feb 1st as your last payment. You will then lose the $500 as if you just gave me the cash for wasting each others time!
