Car will shift into 1st and reverse. But none of the other gears?
I had just gotten done rebolting my flywheel. The car is all back together. Well when the car is off I can shift easily into all gears. Although when the car is on it only wants to shift in 1st and reverse? It doesnt jump at all in either of them. What do yall think it could be?
Village Troll
Trans need to come back off. That's all there is to it. It could be your clutch is dragging. How much did you torque your pressure plate to? Did you make sure the part of the hub that sticks out went into the flywheel?
