Update 12-21-12
Old 12-23-2012, 08:35 PM
Sofls1's Avatar
Default Update 12-21-12
It's been a while since I have posted anything on here, so I figured after a long year of not being able to get to the track, from making some repairs due to a broken valve spring, and just little things tripping me up all year I have finally gotten back to the track, so I figured I'd share.
The first outing I didn't fare so well, but still went a 10.33 @132. but the car was lazy in the 60ft. The converter change and the rear gear I had just didn't like each other at all with my setup. (my previous best was a 10.22 @ 132 w 1.41 60ft)
Since the car felt lazy on that pass and in general, and the shift extension was ridiculous, I decided to switch to a 3.73. This immediately made a nice difference. Eager to see the results, I headed back to the track this past Friday. Unfortunately due to the long drive up there, and a few other racer's unfortunately luck of catastrophic failure leaving the track swimming in oil most of the night, I was only able to get one pass in.
While it wasn't a NPB, I did get a NPB in the 60ft. (1.39), and ended up with a 10.26@131.86. Considering the odd things that went on this night (maybe it was the Mayan's lol) I feel like I am back going in the right direction.
Big thanks to Carter01 for all the help, and everyone else that has been posting up results lately, definitely shows me that my goal of making a 9 sec pass is close!
Old 12-23-2012, 09:29 PM
Killer5.3's Avatar
Man that thing is moving out. What jet are you spraying? That converter and gear should work good together up to a .078 jet. Ours is blowing through the converter some on a .088 jet with the SS3600.
Old 12-23-2012, 09:43 PM
Sofls1's Avatar
thanks!
.067 jet- old hsw plate, but I have a fast and 243s, the converter was a SS3600 that I sent to Lane @ PTC, he changed the stator in it and moved it up a little higher in the powerband.
Old 12-23-2012, 09:55 PM
Killer5.3's Avatar
Originally Posted by Sofls1
thanks!
I think that plate will flow 200 worth. Put some jet in that thing and you got your 9 sec slip! Then heads and Fast should put you in the 9.60-70. We are sending our converter to PTC very soon to let them work their magic on it. With Andy helping you it won't be long before you get there. He has been a big help to us with his advice on the nitrous tuneup.
Old 12-23-2012, 10:04 PM
Sofls1's Avatar
I did grab a .073 jet last week, but I have a few things left on the table with this jet. I'd like to get some more track time and use some more of Andy's advice before switching. My problem is just getting the track time, but hopefully in the next month or so I will be able to get a few weekends in.
PTC was great to work with, I'm sure you will be happy with those changes.
Old 12-24-2012, 06:30 AM
Justins00ss's Avatar
Congratulations buddy. Not too sure if I will make the rental in February but would like to see it go again in person. Love the NBM color. After I get mine running I need to have Greg from anti venom tune it.
Old 12-24-2012, 08:09 AM
Sofls1's Avatar
Thanks Justin,
I saw you got another shortblock, the rental is feb 10th brotha - you can make it. Be good to see you back out
Old 12-24-2012, 08:32 AM
Thanks. I forgot to ask. Are you just tuning with HP tuners and reading plugs? Do you have a wide band?
Old 12-24-2012, 09:39 AM
Sofls1's Avatar
Yeah HP Tuners, I do have a wideband, but I use that mostly for tuning the car on motor. On spray I tune off the plugs.
Old 12-24-2012, 04:25 PM
Carter01's Avatar
Good job Steve, car will go 9.8s easy. Keep up the great work!!!
Old 12-24-2012, 04:42 PM
Cool man. Would love to be in the 10.50s after I get running again. Only thing I am worried about is the 4.11 rear gear hurting more than helping
Old 12-24-2012, 05:54 PM
Sofls1's Avatar
Thanks Andy!
Old 12-24-2012, 06:02 PM
Sofls1's Avatar
You can get it there no problem, if you need a hand let me know. I wouldn't worry about the 4:11 just yet, it's probably not optimum but not holding you back from going 10.50, you can address that after you get it back up and running.
Old 12-24-2012, 06:09 PM
Thanks bud. Not to many of us ls1 nitrous guys on n2s any more. Need all the help and advice I can get
Quick Reply: Update 12-21-12
