valve relief help needed
Old 12-23-2012, 08:47 PM
M1SERY's Avatar
Question valve relief help needed
Uncharted water, help needed
I'm in the process of fly cutting my pistons and i was looking for some references to figure out how many cc i am cutting into my piston so i can calculate my compression ratio
if i'm cutting eyebrows for the lack of a better word, does any one know how many thousands equal 1cc in my stock ls1 pistion,
tried the search engine, no good references just vague and generalized, what i did find, i didn't know if it was a cubed measurment or measured by the depth of eyebrowed cut in the piston.
2.02"/1.575" Valves
Old 12-24-2012, 04:37 AM
IllusionalTA's Avatar
The issue is you go per se .015, the center of the "brow" is deeper than the outside, so you can't just say x = y... only true way is to cc it... otherwise your better off just calculating your CR w/o factoring in the cut's.. It'll get you a ball park..
Quick Reply: valve relief help needed
