first data logging not sure on what to use?
Old 12-25-2012, 03:41 PM
Gfleck047's Avatar
Default first data logging not sure on what to use?
i am doing my first turbo ls1 e85 build.. i am new to fuel injection and computer controled stuff. i have always used carbs. i am not sure what tuning software would be best for me.. the car is a jy built motor in a 25.5 fox mustang. i am going to have the car tuned professionally when i get it done and together. i still would like to be able to record everything from timing and boost to injector duty cycles fuel logs and egts for each cylinder if that is possible. what would be the best user friendly tuning and data logger be. i have a laptop for just doing my racecar.
Old 12-25-2012, 03:51 PM
MontecarloDrag's Avatar
Which controller are you using for engine management? OEM or aftermarket?
Old 12-25-2012, 04:31 PM
Gfleck047's Avatar
i was gonna have a stand alone OEM harness made
Old 12-25-2012, 04:45 PM
For a OEM PCM you can use Hptuners or Efilive, both are very good and do what you need
Old 12-26-2012, 07:17 AM
Old Geezer's Avatar
EFILIVE here.. Using a custom operating system from the EFILIVE forum. [COS]
Quick Reply: first data logging not sure on what to use?
