72 Chevelle exhaust question
Old 12-25-2012, 06:09 PM
jlay's Avatar
Default 72 Chevelle exhaust question
I am about to install my 5.3 in the chevelle and don't really know what to do about the exhaust. The small block that came out of the car had headers, but I don't know if that is what I want to go back with. The car will be a daily driver and the 5.3 is stock other than a ls6 cam. Are the truck manifolds pretty good? I really don't want to spend another $500 when I am already over budget on the swap already.
If I do go with manifolds, who makes the pipe from the manifolds to the flange with the o2 sensor installed.
Thanks in advance, and Merry Christmas!
Old 12-25-2012, 11:25 PM
bczee's Avatar
If it is going to be a DD, even with theLS6 can, you should be OK with OEM manifolds. You can find the flanges at Speedway motors, but most likely you well have to get a exhaust shop to bend you up some pipes. You might also pull some from the junk yards....
Old 12-26-2012, 06:17 AM
oldgoat69's Avatar
Stock manifolds should be just fine, they worked on the original engine so why not on yours? I agree with bczee regarding the head pipes, just remember to get the o2 bungs if they are not in the manifolds.
Old 12-28-2012, 12:14 AM
LSjim's Avatar
I put on fbody pacesetter long tubes!!
Old 12-28-2012, 06:21 AM
99VetteFRC's Avatar
When I put the truck manifolds on my Chevelle, the flanges were to wide for my framerails, that could be just where I set my engine, so I cut the flanges off and welded V-Bands to them. Then I had to take the Proportioning Valve on the inside left framerail and unbolt it and push it up out of the way. After that they worked great!
Old 12-28-2012, 07:59 AM
garys 68's Avatar
I used the 98-02 f body manifolds. They support at least 350 hp, fit between the frame, dont hit the firewall, clear my z bar, and cost me $40 used. I could not get the truck manifolds to fit in my 72 442. You'll need O2 bungs welded in just below the collector. Got my flanges from speedwat motors.
Old 12-28-2012, 07:49 PM
jlay's Avatar
Thanks guys. I wonder how close the f body and gto manifolds are? The motor for my camaro came from a wrecked GTO and the guy still has the manifolds.
Old 12-28-2012, 07:52 PM
downset71's Avatar
Gto manifolds dont work on an A body. Trust me. F body manifolds best cheapest way. I have them with no issue.
Old 12-28-2012, 08:10 PM
jlay's Avatar
Thanks!
Old 12-28-2012, 09:10 PM
71ANTICARB's Avatar
Used F-body headers, almost like they were made for it.
Old 12-28-2012, 10:50 PM
jlay's Avatar
What year/type f-body headers fit? I thought the drivers side kick to the outside of the car.
bczee's Avatar
I used the F_body manifolds before I went with headers. Minor areas of contact with the driver side O2, I plugged the OEM location and welded a.new bung 90 degree to better clear the streeting box.
Quick Reply: 72 Chevelle exhaust question
