Ls1 reads 0psi on All 8 cylinders
Old 12-26-2012, 08:23 AM
prerunner404's Avatar
Default Ls1 reads 0psi on All 8 cylinders
I'm trying to diagnose why all 8 cylinders read 0psi. Motor was running did a wcch 243 head swap and now nothing. Head gaskets valves ?? Anyone's thoughts? Help!!!
Old 12-26-2012, 08:40 AM
Camaroo1's Avatar
ALL the valves are stuck open? Check you push rod length BUTT 1st pull ALL the rocker back off then do a comp test.
Old 12-26-2012, 09:39 AM
A.R. Shale Targa's Avatar
push rods are too long by at least .025". This bottoms out the hydraulic lifter
plunger and essentially makes it solid, then begins to open the valves......IE
no compression.
Old 12-26-2012, 09:45 AM
VandykeT/A's Avatar
Yep, valves are open. What pushrods are in it?
Old 12-26-2012, 02:50 PM
Stock length 7.400" springs have a max lift of .600 what length push rods do I need?
Old 12-26-2012, 03:51 PM
Tainted's Avatar
You need to measure thats how you find out.
Aftermarket cams normally have a smaller base circle, and if you have milled heads thats a factor also.
Old 12-26-2012, 04:48 PM
ok still a stock cam
Old 12-26-2012, 04:54 PM
bwolfZ28's Avatar
Maybe a dumb question but is the gauge broken? Someone I know had that issue and it was the gauge.
Old 12-26-2012, 05:26 PM
no gauge was just used on a diffrent motor and read accordinly.
Old 12-26-2012, 05:37 PM
bww3588's Avatar
Did you put spark plugs back in?
Old 12-26-2012, 05:45 PM
yes same out come you can hear when cranking motor over that there is no compression.
Old 12-26-2012, 08:36 PM
dirtbag's Avatar
If the cam was out, or timing chain off, maybe you have the timing off causing the valves to hang open. Either that or too long of pushrods. I would get a pushrod length checker anyway its a nice tool to have around at $20. Also if you had too long of pushrods, the lifters are probably bled out like someone mentioned above from being turned essentially into a solid lifter. If it was me, I'de pull the heads and re-soak the lifters in oil again before firing the motor up with the right pushrods.
Old 12-26-2012, 11:19 PM
RonSSNova's Avatar
Even if the heads were milled .030, the pushrods would not be too long.
My guess is that the lifters are pumped up from the old setup and the valves are hung open. I would think crank it for a bit and see if the lifters re-center.
Old 12-27-2012, 07:27 AM
LS1MCSS's Avatar
Did you leave off the rocker arm pedestal when you put it back together? It sure sounds like it.
Old 12-27-2012, 08:02 AM
yes i pulled the rocker arms off completly when i pulled the old heads and installed the existing rocker arms onto the new heads. rocker arms are oem with the motor.
Old 12-27-2012, 08:04 AM
i would guess the motor has been cranked atleast 40 times to try to start should that be substantal enough to recenter the lifters?
cam and timing chain have never been removed.
Old 12-27-2012, 08:09 AM
Camaroo1's Avatar
Did you remove the rockers and try a comp test?
Old 12-27-2012, 08:47 AM
bww3588's Avatar
soaking the Lifters will make it worse. That is the last thing you want to do to a lifter. Assembly lube or a quick splash of oil is enough.
Old 12-27-2012, 08:53 AM
no i did not
Quick Reply: Ls1 reads 0psi on All 8 cylinders
