Steam Pipe
The factory sealing washers with the rubber insert seal the steampipe banjo fitting to the cyl head and to the large washer head on the bolt. I would stay away from using RTV on the steampipe or the bolts, if some RTV extruded into the steam pipe or hollow bolt it could clog it up. I would use anti-seize on the steampipe bolts, if antifreeze leaks up the bolt threads it will be trapped by the sealing washers, no pipe sealant required.
