Help with MAF vs MAP and DBW
Old 12-26-2012, 11:45 PM
tehsocksz28's Avatar
Default Help with MAF vs MAP and DBW
Ive bought myself a LQ4 block which i plan on putting into my 85 Z28.
I'm trying to gather parts for my swap right now. Based on reviews, reading the forum, etc... I think im going to be going with a TSP 228R cam, 112lsa.
My question is, do i run this MAF or MAP.... Or both? Not 100% sure of the PCM operations of an LS.
A local seller in my area has this for sale for $1000
Painless Performance 60221 Harness Kit (NEW in the box)
OEM ECM (computer) for this harness (flashed already to remove the security lock out)
OEM DBW Throttle Body (3 bolt mount)
OEM DBW Throttle Pedal & Mount
OEM TAC Module for Throttle Pedal
Transdapt Throttle Body Extension (increase performance)
Street & Performance Billet MAF/Air Filter Combo (NEW)
I know this is a good deal. But is DBW a 58x thing? My engine is a 24x wheel, and would DBW be ideal for my swap?
Old 12-27-2012, 09:17 AM
Super Moderator
Reckless's Avatar
Stock ECU will work best with both.
Old 12-27-2012, 09:30 AM
bczee's Avatar
You would need both for the stock ECU/PCM... if you do a Speed Density Tune, then you can do away with the MAF.
Old 12-29-2012, 06:57 AM
LS1Tech Sponsor
psiconversion's Avatar
Agreed with above, you want to use MAF and MAP in a relatively stock application.
Question, Does the kit come with the TAC Module Harness? Make sure this is a Green/Blue Harness.
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Quick Reply: Help with MAF vs MAP and DBW
