Oil Pump, swap or not?
Old 12-27-2012, 12:24 PM
Zfan's Avatar
Default Oil Pump, swap or not?
Ok, so I have a L76 that I am deleting the DOD and VVT, Installing a EPS 230/242 cam, springs and pushrods. The oil pump in it is a hi pressure style pump I believe, would it hurt to run it after the mods or should I swap it out for a stock lS2 unit.
The reason I am asking more than anything is I keep hearing about folks running hi volume/pressure pumps and wonder why change it out seeing is it is a hi pressure pump. Can the spring just be swapped out? If it needs to go what one is recommended?
LSX motors are new to me, I have never worked on much of anything but first gen sbc, 350,383,408's.
Thanks,
Mike
Old 12-27-2012, 06:49 PM
litle88's Avatar
I'm not sure if the L99 and the L76 share the same pump BUT an Ls2 pump is no better in quality that's for sure lol. If I was in the middle of a build I'd just get a melling just because of the better materials and components and the option to leave the high pressure spring in it. I have had the same melling for about ~30k miles. I had it in my Ls1 and now my stroker. Just my .2
Old 12-27-2012, 09:47 PM
Zfan's Avatar
What melling pump, parts number? Appreciate it!
Thanks
Mike
Old 12-28-2012, 12:18 AM
litle88's Avatar
Here you go
http://www.ws6project.com/user_stor/...oducts_id=2510
Quick Reply: Oil Pump, swap or not?
