Changed cam and lifters slowly lost oil pressure metal in oil (pics inside)
I changed the cam in a friend's car with him and the car slowly lost pressure and went all the way to zero after about a little more than and hour of driving. The cam is a TSP 228, LS7 lifters, springs and new trays. Re-used the stock timing set and threw it all together. It ran and idled fine but still needed to be tuned. Drove a bit then lost pressure. Pulled it down and the cam sprocket rubbed the retainer plate and the cam retainer plate gasket looked torn. I wouldn't think that the retainer would let the oil pressure go to zero, maybe low but not zero. I still can't see why the retainer plate was rubbing. It was bolted to the block tight. Here are some pics and maybe you guys can tell me.
What Tim and Joe said^^^^^^
This made no noise when you started it?
What do the bolt heads look like?
Looks like the damage to the area around the plate bore is not the same depth, all the way around. Plate looks to have been on crooked?? [Or, left loose]
Were the bolts torqued, prior to completion of the install?
Ne of the lifters damaged from cam walk?
Well what we came up with is that my buddy was kinda not double checking himself and the bolt backed out and caused the issue. I wasn't there to watch when he put the timing set together. I slid the cam in for him and had to leave then he did the rest. Picked up a new retainer plate and gasket and new sprocket. It will be back together next week and we will see how it goes.
