T&D Shaft Rockers
T&D Shaft Rockers
Just wanted to share my latest addition to my LQ, L92 head motor. No track time with the new parts as the winter has set in in New England.Few more little things to do in the Spring.....then we'll see
Funny you ask.....that has not been fun. tried 2 styles of valve covers, PRW for one with the clearanced rails (side toward the intake) ...no go, I really liked the covers to. Had to sell them at a loss. Currently have 1/2" spacers that I had to grind the crap out of. Not sure if this is the final solution as I have put the car away for the winter. I really dont like the way it is now, so plan to do some more work on the issue. The spacers I have dont really fit the heads super tight so they slide toward the bottom of the heads resulting in the face of the rockers coming in contact with the spacers. Not sure what I will do next but have to do something to correct the problem. I even called T&D for suggestions and the were no help. They basically said it's your problem. They said get custom covers made, like I have a grand for custom billet covers laying around. I'll get it figured out eventually.
PS...Nice times with your Mustang!!
T&D shaft rocker valve covers
I have a set of T&D shaft rockers and went through the same thing. I tried using a set of 1/2" spacers with the stock valve covers. This required a lot of grinding and they still didn't clear. I ended up buying some cast aluminum valve covers from Katech. They fit with no mods.
1/2" spacers
T&D shaft rockers 1.8 ratio
Katech cast aluminum valve covers installed
1/2" spacers
Thanks for the replies.....My spacers look exactly the same.....Found some All Pro covers that I'm trying next.
I think the Proform LS covers fit too and have a coil mounting option: http://www.proformparts.com/category...formance_Parts
Roger: Which Proform # did you use I had to take a little material from the cylinder head behind the rocker (toward the intake manifold side) to get them to clear. Did you have to remove material from the valve cover rail?
