Help Car Will Not Start
First Things 1st have a 2001 z28 camaro 53,000 on motor.....Has TR Raptor cam...Just brought some 243 heads and had them milled .020 put the heads on with the 7.400 harden push rods.....The car was hard as hell to start when it did start it had alot of valuetrain noise so i shut it down immediately...Now car dosent want to start at all...Still is getting Fuel and Spark....While trying to start the car there's white smoke cuming from value cover and Throttle body....I changed crank sensor and Spark plugs but car still will not Start.....im all out of ideas if any one has been thru this before Plz give me so insight im all out of Ideas Here.......Thanks
He milled the heads. Didn't measure for pushrod length, and added a larger
Cam with longer duration so he's hanging the valves open longer. My guess is
Bent valves. I would pull all rockers off and do a leakdown test.
The ground strap on the back of the driver side head caused an intermittent start then a no start when I did my swap. Check that it has a good connection (I.e. sand it if necessary)
@justafool swaped them over n still no start
@wytry check the connection its pretty tight also changed my knock sensor and still no start Really Lost At This Point
