Re installing heads on 97 SS...
So i purchased the Fel Pro head gaskets and Bolt kit... Are these gonna be ok? Heads have been off for a month or so.. I have the cylinders taped off as not to let any debris inside. Just purchased car and there is "some" small surface rust inside cylinder walls.. I cleaned, placed a light coat of oil inside and taped when i got the car home. I'll be throwing some new lifters in as well.
Anything i am missing?
Dont forget to torque the bolts properly and in sequence and try to do it all warm.
Lube and seal the bolts the same for conformity. Make sure all surfaces are FLAT and CLEAN!!!!
I used rubber seals from a Gen1 SBC and a dab of black RTV on the corners..
