Talk me out of / into over sizing the rear tires
Im getting new rims on a 1978 Camaro Z28..
1978 stock Z28 is 7"x15" rim.
I was THINKING about going with 9.5"x18" on the rear and keep 7"x15" up front.
People are telling me there is no performance need, it just makes the rear end wander, putting smaller diameter on the front makes the car lag (like a dump truck pushing a load..) etc...
So someone make an argument for going bigger and wider on the rear! (I mean that in the dirtiest way possible)
1 Post
A wider tire on the rear is usually a good thing, a bigger diameter wheel is only good for better handling. If you put a 18" wheel on the back it would look and handle much better if you put one on the front also regardless of the width of the front wheel.
