Camaro Twin Turbo Kit
Old 01-04-2013, 01:01 PM
granatelli sales's Avatar
Default Camaro Twin Turbo Kit
A detailed break-down of the 2010-2011 Camaro Twin-Turbo kit and its components are as follows:
2 x PTE6265 Turbochargers with 4” Inlet Compressor ducting – Each capable of 65 lbs/min
Turbos are V band mounted on inlet and outlet to insure easy rotation, solid mounting and best of all there are no nuts and bolts entering or exit turbo body
2 x PTE 46mm Waste Gates Insure Maximum Control Over the Monster
Turbos. Waste Gates Include Adjustable Springs to go from 4.5psi to 15psi (We factory set them at 7lbs)
All stainless steel and Heat temperature coated exhaust system components ensure a lifetime of reliability
1 x 50mm Tial Blow Off Valve
3 x Largest Front Mount Intercooler are Hi flow Bell cores with 3.5” inlets from turbos and a single 4” discharge pipe feeds direct to the throttle body. Intercooler Tanks are Black Powder Coated to Extract Heat Yet Fins Remain Untouched
Fiberglass Reinforced Silicone hose couplers ensure durability for year to come – no expense was spared
All the necessary Vacuum ports required to assist in installing the boost controller
1 x Oil Scavenge Pump & Brkt
Thermal Heat shielding for all effected lines
GMS Oil Feed & Return Line Kit are all precision clamped and crimped to ensure leak free connections
GMS/TTi 3.5” 6061 Aluminum Intercooler Tubing for lighter weight and better heat dispersion
GMS/TTi 4” 6061 Aluminum Charge-pipe
GMs/TTi 4” Aluminum Intake Tubing w/K&N Filters and K&N “Hydro Shields” for extended dust/dirt/water protection
GMS/TTi Aluminum Lower frame cover to ensure debris free road travel
The only TT kit that does not hang below the frame rail, ensure plenty of ground clearance
AEM Windshield Washer Bottle & Accessories
Polished Oil Cap w/oil return
Retains Factory Engine Cover
We offer many options from short blocks and long blocks to various turbo size upgrades and color choices. Factory Silver Powder Coated Tubing – Special
Colors Available on Request.
CALL 805-486-6644
for MORE information
Here is a video dating back to Jan 2010. Naturally we make more power now
This pictures shows our kit installed with a TVS2300. We offer it as a compound boost set up as well. These pictures show the kit better with the engine on the stand
Please note below how OE this kit is once complete
I agree if you want only eye candy this is not perhaps the most flashy. But if you want the max amount of power per pound of boost and only the best will do...you can't beat this kit for fit, finish and the way it just works
This is the power you can expect out of the box - as shipped. Or just keep turning up the boost all the way to 1200hp.:thumbsup:
We all know a stock motor can't go that high and we are not saying that. If you install this kit the power allows you to go from 500 to 1200. You will not need to spend more money on pulley changed and exhaust upgrades
Attached Thumbnails Camaro Twin Turbo Kit-170104.jpg   Camaro Twin Turbo Kit-461634cf587fc57fd9100_1920.jpg   Camaro Twin Turbo Kit-921194cf587fe6e3eb100_1922.jpg   Camaro Twin Turbo Kit-218174cf5880aa7277img_4394.jpg   Camaro Twin Turbo Kit-859574cf58813525e0img_4563.jpg
Old 01-07-2013, 09:39 PM
Blackpanther99's Avatar
Nice setups.
Old 01-10-2013, 05:48 PM
merim123's Avatar
very nice looking setup, looks well put together and thought out.
Old 01-11-2013, 01:31 PM
We tried going for the clean low profile look
Old 01-11-2013, 07:12 PM
2002TTTA's Avatar
whats the biggest turbos you can use with this kit?
Old 01-12-2013, 04:08 PM
I8UR4RD's Avatar
615 on 7 lbs is nice.
Old 01-14-2013, 04:25 PM
6265 turbo is what the kit is designed for
Old 01-21-2013, 01:03 PM
WE ALSO DO CUSTOM COLOR
Old 01-21-2013, 02:50 PM
Sale on all twin turbo kits pm for prices or for faster response call (805)486-6644
Old 01-23-2013, 06:25 PM
Toxic-Evo's Avatar
can oyu post a an instruction manual??? or is it on your site??
i want you kit. but dont know if i can go it or if i need a shop to.. so i would like to look at how it goes on.
Old 01-25-2013, 01:07 PM
HERE ARE INSTRUCTIONS
http://granatellimotorsports.com/ima...structions.pdf
Old 01-28-2013, 12:39 AM
dregg100's Avatar
is that dyno graph of the turbos alone, or the twincharged setup? stock 6.2?
Old 01-28-2013, 01:31 PM
this is with just our twin turbo kit
Old 02-13-2013, 01:19 PM
new pictures coming soon
Old 02-13-2013, 01:35 PM
there is still one more turbo kit left on sale for a great price PM for more information
Old 02-13-2013, 01:50 PM
Really good results.
Old 02-18-2013, 03:58 PM
CLEAN LOOKING SET UP
Old 02-20-2013, 07:00 PM
as you can see we put the turbos where the cats go so its like nothing really was changed
Old 02-22-2013, 03:52 PM
Old 02-22-2013, 05:27 PM
venom ws7's Avatar
Great looking kit..
From the pics it seems you can fit 6766??
Quick Reply: Camaro Twin Turbo Kit
