Feeler: LS2 Engine (Nearly long block)
Category: Accessories
Price: $3000
Part Fits: Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): CT
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9
LS Engine?: Fits LS Engine
- LS2 shortblock with 28,000 miles--oil changed before the engine oil life meter hit 50% (8 times total over the life of the engine)
- 243 heads with Comp 26926 dual springs good for .675" lift (3,000 miles on them), steel retainers, Comp steel locks, proper shims, etc
- Stock GM LS1 style rocker arms with Comp Cams trunion upgrade kit (3,000 miles on it)
- TRuTorq L3 cam installed, LS2 cam included separately
- Stock LS2 lifters
- Requires 7.425" pushrods (not included - I still have the original 7.400" ones if you want them)
- LS2 water pump
- Keyed crank using Comp kit and key
- Stock LS2 oil pump, timing set, and chain
- Stock fuel injectors
- Water pump and timing cover seals replaced 3,000 miles ago
- Professionally ported (LS2 Port Works) LS2 intake manifold (3,000 miles on it)
- Valve covers, fuel rail, trays, coil packs, etc not included unless you need them--I may use them on my new build, but not sure yet.
If you have any questions, feel free to contact me. I should have pictures up in the next two months. Sooner, if I decide to swap my LSA heads onto this thing. Would prefer a local buyer, but open to all offers.
