installing TSP231/237
Old 04-15-2004, 04:31 PM
badazzhawk's Avatar
Default installing TSP231/237
i'm installing the Tsp 231/237cam with crane dbl valve springs... harden pushroads...retainers, seals...do i need a ported oil pump or a stronger timing chain right now..or is what i got ok..also has anyone used the more valve spring compres...is it worth the money...or which valve spring comp should i use...(heads are stayin in the car for now)
i always hear different things on this...how long is break in...some people say a few hot cold runs...and some others say 300 miles...what do u guys think..thanks...
Old 04-15-2004, 04:50 PM
LS1TECH Sponsor
foff667's Avatar
i didnt do my oil pump or timing chain on my 98 i figured if it aint broke dont fix it and the chain doesnt have that many miles on it now anywayz. I did about 100 miles on mine before i had it tuned.
Old 04-15-2004, 04:54 PM
badazzhawk's Avatar
Default ok
so basicly go about 100 miles...change the oil...then its pretty much broken in..then tune it
Old 04-15-2004, 05:07 PM
LS1TECH Sponsor
foff667's Avatar
i actually just heat cycled my springs like 4-5 times, changed the oil, drove sane for the next 100 miles till i got tuned.
Old 04-15-2004, 05:17 PM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
Change oil at 300 miles max.
Old 04-15-2004, 05:32 PM
badazzhawk's Avatar
Default k sounds good
sounds like a plan thanks guys...ill let u know how it all goes..i'm suppose to ravce a evo once i'm done and tuned...evo has a down pipe...tuned...and up graded turbo...what do u guys think
Old 04-15-2004, 05:49 PM
LS1TECH Sponsor
foff667's Avatar
looks like you'll have your hands full but you should take him as long as you have traction and can drive
Old 04-15-2004, 09:25 PM
!LS1 11 Second Club
Practice your launch and run him 'till 120mph. 70-120mph should be yours.
Old 04-16-2004, 01:28 AM
badazzhawk's Avatar
i'm racing him next week ill keep u guys posted on a new thread..thanks
