LT1 / LS1 parts for sale Yank DynoTune Firehawk
Category: Accessories
Price: $100
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette
Location (State): VA
Item Condition: Used
Engine: LS1/LS6, LT1/LT4
LS Engine?: Fits LS Engine
96-97 LT1 Alternator
This alternator is a little over two years old, but was only on the car for ~500 miles and has been sitting in my garage for the past 18 months, as evidenced by the like new condition and the fact that the labels are still white and legible. $100
96-97 LT1 Master Cylinder & ABS Pump $100
LS1/LS6 ECU This ECU is from a 2001 Corvette Z06. It has the original factory tune and is in perfect working condition. $150
DynoTune Nitrous Bottle Heater Kit / Nitrous Filter / Solenoids / Fuel Pressure Safety Switch FPSS $200
All parts are in good working order.
LT1 4L60E Transmission Rebuilt to Pro Race specs by Frank Cahall @ CPT. Trans has 0 miles on it since being rebuilt. Trans also has an aluminum B&M deep sump pan installed. Will come with the dipstick, crossmember w/ poly mount, and the dust shield. Also already has a temp sensor installed for a trans temp gauge. The ONLY thing wrong is one of the bolt holes for the dust shield is cracked as shown in the pics. Build specs can be found here: http://cpt.pszweb.com/700.htm $1000
Black ZR-1 Replica wheels with narrow machined band. These wheels are no longer made, only the wheels with the larger band are available. These wheels are as close to new as you’re going to find. There is NO curb rash on any of the wheels. There are VERY MINOR scratches in some (as seen in the pics), but they clean up very well. Will come with the WS6 centercaps (those are over $100 by themselves) and 2 Toyo Proxies TR1 255/40/ZR17 tires mounted and balanced. Tires are almost brand new and have less than 1000 miles on them. $500
96-97 OBD II LT1 ECU. ECU has a tune which deleted all of the emissions equipment and A/C trouble codes. Tuned also for long tube headers and for premium fuel only. ECU will come with a LT4 knock module installed. VIN will be provided so if a retune is desired it should only cost $50 through MADZ28. $175
