1979 Corvette, 383 & 700R4 Tampa, FL $9000
Year: 1979
Make: Chevrolet
Model: Corvette
Price: $9000
Mileage: 135500
Private or Dealer Listing: Private Listing
Location (State): FL
Color: Beige
Transmission: Automatic
Drivetrain: Rear Wheel Drive
Engine
- Professionally built 383
- Rebuilt at 115,030 miles
- Eagle 4340 forged 3.75 stroke crank
- Block decked & bored .030
- Eagle 57 H-beam rods
- King racing bearings
- ARP bolts
- Keith Black flat top 10.5 pistons
- Plasma moly rings
- Comp High Energy Cam Lift: 480 / .490, Dur: 230 / 236, Sep: 110
- Comp anti pump up lifters
- Comp Cams premium .080 push rods
- Harlam Sharp roller rockers 1.5
- Trick Flow 23º aluminum heads
- Summit Racing 750 CFM carb
- Weiand Intake
- Roll Master double roller timing chain set
- Dynagear high volume oil pump
- High flow aluminum water pump
- New fuel pump
- HEI Distributor
- SFI approved flex plate
- 105 Amp Alternator
- Dual electric fans
- Hi-Torque mini starter
- Starter heat blanket
- Headers are wrapped w/black wrapping
- Hooker sidepipes w/Sweet Thunder 2" Inserts
Transmission
- 700R4
- BEAST sun shell
- corvette servo
- Raybestos Z-Pak clutch set
- New linkage and indicator set
- Hi-performance 2800 L/U torque converter
Chassis / Drive Train
- Drive shaft mod. & balance by Crane Co.
- All new universal joints
- New rear end seal set
- 3.55:1 ratio LS differential
- New diff yokes
Body / Interior / Etc
- 2-1/4" rise cowl hood
- Flex fiberglass bumper
- New carpet
- New rear storage compartment
- Year 2000 Corvette rims
- Aftermarket electric locks and keyless entry
Things you may care about:
- AC/heat Blower motor is not wired up
- AC is not charged (but is fully hooked up)
- Dash has a plastic cover which is ******. It needs to be replaced with a real dash.
- E-Brake is not hooked up.
- T-tops have no trim panels
- Interior door arm rests/panels could use a replacement.
- Carb could use a tuning.
- Could use a repaint. It has lots of nicks/dings/etc. The previous repaint wasn't great.
- Top drivers side of hood is cracked. Could probably be repaired.
- The body mounts might need to be replaced.
- There is no spare or spare carrier.
