Cam Experts needes!!!!!
Need help with this, I have a comp 230-230-600-600. Will this work with a stock ls1 shortblock with LS6 heads milled 10 thou. Also will I have to flycut the pistons?
It should work fine as long the springs can hold a .600 Lift, Comp 921 dual springs would be recomended.
My friend has 99 ws6 with stock LS1 heads. 921 dual springs with cam that is 604 Lift and it work great and his car is an A4.
You should be fine as long as its properly TUNED
