ls1 swap guys- radiator ?
Old 01-08-2013, 09:00 AM
Boosted Firehawk's Avatar
Default ls1 swap guys- radiator ?
ANY ls1 swap guys running stock lt1 radiator and fan setup still?
can it work and will the hoses connect to each other?
Will I have to use ls1 hoses or lt1 hoses to the radiator or find ones that will match?
thanks in advance
Old 01-09-2013, 05:19 PM
Pocket's Avatar
You will need to track down suitable hoses, but size/function will work fine
Old 01-09-2013, 05:30 PM
stangtrader's Avatar
Use your lt1 radiator with ls1 hoses if your using a fbody water pump.
Old 01-09-2013, 09:41 PM
yes I am using a ls1 electric water pump
Old 01-09-2013, 10:01 PM
All you need to do then besides use ls1 fbody hoses is cap off the hose hook up on the bottom of the drivers side tank
Old 01-12-2013, 02:52 AM
the_merv's Avatar
I use the LT1 Radiator & Fans in my 84 MCSS..works perfect.
Quick Reply: ls1 swap guys- radiator ?
