My ls1 Foxbody t76
Old 01-08-2013, 10:54 AM
LSX FOX's Avatar
Default My ls1 Foxbody t76
Got my project finished a few weeks ago and finally got to take some pictures.
Attached Thumbnails My ls1 Foxbody t76-picture-159.jpg   My ls1 Foxbody t76-picture-165.jpg   My ls1 Foxbody t76-picture-167.jpg
Old 01-08-2013, 12:44 PM
boostnut's Avatar
Nice. Are those F-body accessories in the stock locations? If so, what manifolds are you using?
Old 01-08-2013, 12:48 PM
LSX FOX's Avatar
yea but my manifolds are fabricated alot on the driver side to keep heat away from my alternator..here soon im going to be putting my ac compressor back in and converting the lines..but ill have to ask my teacher what manifolds they are, i traded my camaro manifolds for them..but yea all the accesories are in the stock locations with the stock brackets and everything.
Old 01-08-2013, 09:20 PM
boostnut's Avatar
Originally Posted by LSX FOX
yea but my manifolds are fabricated alot on the driver side to keep heat away from my alternator...
Huh? Looks like a stock manifold of some sort with a vband clamp welded to it. Care to explain?
Old 01-09-2013, 10:40 AM
LSX FOX's Avatar
ohh yea they are stock manifolds, i meant the manifold has been fabricated alot on the driver side to not be so close to the alternator..its capped off on the end and then a hole was cut and a pipe welded on the side..the passenger side manifold flange was only chopped off and a vband welded on with alittle extra pipe for length away from my kmember.
Old 12-21-2013, 06:50 PM
carbed86fox's Avatar
Did you get beat by a heads cam ls fox ?
Quick Reply: My ls1 Foxbody t76
