Factory sized lower ball joints
Old 01-09-2013, 06:42 PM
lees02WS6's Avatar
Default Factory sized lower ball joints
Raybestos and Moog are both 20 thousandths bigger in diameter than factory ball joints. Unless the the arm has had it's joint removed and replaced several times this makes "oversized" ball joints like the Moog a pain to press in.
Moog, AC Delco, and Raybestos ***-u-me that all control arms have boogered up lower ball joint holes. They oversize the joint, and that makes it a pain to press in new ones.
https://ls1tech.com/forums/suspensio...ll-joints.html
https://ls1tech.com/forums/suspensio...ints-suck.html
https://ls1tech.com/forums/general-m...eat-fully.html
So, my question is are there any factory sized replacement lower ball joints around?
Old 01-09-2013, 07:15 PM
sjsingle1's Avatar
maybe get a new arm?
Old 01-09-2013, 08:31 PM
Spartan7's Avatar
What are you using to press them in? If it's that cheap Autozone rental tool, good luck with that. A local shop had no issues pressing my Moog lower ball joints into the stock arms.
Old 01-09-2013, 11:01 PM
sjsingle1's Avatar
i used a heavy duty stand alone press...........that on the car tool would have NEVER done it......it was still a PITA !!!!
Old 01-10-2013, 08:56 AM
lees02WS6's Avatar
Shop press, couldn't get the ball joint to go in straight.
Old 01-27-2013, 10:14 AM
lees02WS6's Avatar
This isn't seated all the way is it?
It seems like this lip
needs to be flush with this landing
Old 01-27-2013, 11:08 AM
TransAmBlue's Avatar
Take a flat file and remove some.
Old 01-27-2013, 03:35 PM
lees02WS6's Avatar
I answered my own question. They are definitely not pressed in all the way. Went in at an angle, which can be seen better through a hole on the bottom next to the shock mount holes. These things are murder.
Quick Reply: Factory sized lower ball joints
