What turbo for my 390ci (T6 Flange)
Ok, I know I made this thread not to long ago but that was when I was trying to go t4 flange. I changed my kit around and now its gonna be a t6.
Looking for 1000whp on e85, trying to not go past 20psi, don't want to buy aftermarket heads. My cam has 10 degrees of overlap as well. I was thinking a GT50-88 or a hp-91 from Borg. Any advice would be greatly appreciated.
The GT50-88 has a 102mm turbine, I thought it would work well with my cam and all. I know a GT-88 can make 1100whp automagic did it on a 408 but it had a ton of boost if I remember right.
LS1Tech Sponsor
BW S480 with the 88mm wheel upgrade!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Nobody said that. An 88 is plenty of compressor to make 1000 wheel. You were trying to make over 1000 on a 390 with a physically small turbo, which is not happening. You need enough turbine to use all the compressor is capable of giving and not run into backpressure issues.
But everyone agreed a 91 or bigger will do the job. But then there's lag.......
Screw the single turbo idea. Too much BS, especially for a street car/roll racer. And after seeing that a single turbo set-up in the end, including labor and fabbing to install.....will be MORE MONEY than the ModTurbo TT kit out the door ready to drive......no brainer.
This is why I'm going MDTT.....over-all the consensus was that I will not reach 1,000 RWHP through my 4L80E..........everyone pretty much said that.
Where have you been, i would hope 140+lb/min 88s out there can put down 1k whp
Can lock a 80e up on power with a good converter, it is going to dyno better than alot of combos
Idk what koolrayz exact cubes are but he did say over 400. That 88 is making way over 1000 to the tire. That turbo is gigantic.
