3.8l camaro rs
3.8l camaro rs
took my camaro to a mechanic that allegedly said he would replace the right side head gasket covers to stop the oil from leaking in . When I got it back he said it did not need the job done since it already had a new set and that water had passed into the engine a while back so I needed my engine new or restored with new parts ect. It ran good when I bought it used so not sure if the issue is that deep or he's lying. But when I got it back the car has this issue upon start up where the engine begins to shake on idol. And accelerating feels diffrent. Almost like half the engine isnt working and acceleration sounds muddy. Not sure if its the ignition, or the cylinders. Need an opinion if not to look into a new or different engine.
Thanks
Thanks
Any other symptoms? If only at start up that would tell me the car is still in closed loop and O2 sensors are not giving feed back yet. Which means the engine is getting it's AFR/ and Spark timing from the PROM, ECT, MAP.
Sure it's not misfiring? They are well know for having problems with the coil packs and especially the ICM's
Also, if it doesn't just happen at idle. A leaking (partially stuck open) EGR valve could cause idling problems, and lack of power under acceleration. Excessive carbon build ip could have the pintle stuck.
Two piece intake. It'll be a sandwiched gasket between the UIM and LIM, then a pair of gaskets that mate the LIM to the cylinder heads.
I recommend getting the metal lower intake manifold gaskets from Fel-pro, here's the Part # MS 98014 T
Here's how it looks:
Intake still installed:
Upper intake manifold removed with UIM gasket visible:
Upper intake manifold removed, LIM Gaskets visible (Note they are metal, the stock ones are brittle plastic, even moreso if you still use dex-cool):
