Help Finding a Connector
I am needing to find a connector that will replace the switch in the attached picture. This switch is the fuel door switch from a 2005 GTO. I am wanting to create an extension harness of sorts and make it plug and play. Any thoughts on how to identify what connector to get? And, yes, I have browsed Mouser and some other sites and have not seen something that looks like it will work.
Any help is appreciated.
Other the custom fabrication. I don't think there would be, what I would do is run wires for each pin to desired location then find a way to tuck the wires away, bundling them together. But as far as a extension harness I don't think anyone currently makes them
Edit: are you talking about hooking up a whole new switch all together?
Save the manuals!
It will be easier to figure out by taking a picture of the plug and not the switch. Once you can identify what type of plug it is, then you can easily look up the matching receptacle, which will look different from the switch socket.
Most GM's are easy to look this stuff up, but since the GTO started as a Holden, I'm not sure if they used the same Delphi connector systems. If they did, it should be a sinch and the plug should be in the Delphi catalog.
Thanks. I'll look in the Delphi catalog. I know that the engine harness uses Delphi connectors.
If I needed to make something, where can I get mini spade connectors? I could make something myself to plug into the harness, but the spade connectors would need to be about the size of the spades on the mini fuses, if that makes sense.
