AFR 205's "Maiden Voyage"....
Old 04-16-2004, 02:40 AM
Flow Wizard
Tony Mamo @ AFR's Avatar
Default AFR 205's "Maiden Voyage"....
Gentlemen....
Took the car out late this evening after finally finishing the AFR head/cam/and manifold package as seen on our website. All I can say is the car feels extremely strong....I am very pleased. With a little chassis dyno time to fine tune things, this is going to be a great all around package. After 4500 or so, the car wants to RPM like NOW!! The tach is so far behind its almost a joke....I hit my 6800 Rev limiter so bad the first time I flew forward in the seat. It looks like a shift light is in order for the near future because the tachometer must seriously be lagging by 300-400 RPM's....at least in the first two gears when things are really happening quickly.
By the way, this was my first H/C install on a C5 and I must say all went pretty smoothly....It is certainly time consuming if you are very detailed oriented, but not a bad job to tackle if anyone else is on the fence that might be considering it.
Will have it on the chassis dyno shortly....VERY curious as to how much power we gained...(as all of you are as well!)
I will check back in as soon as I have additional info for you...
Regards,
Tony M.
PS All of you that have waited patiently will definately NOT be disappointed.
Old 04-16-2004, 07:59 AM
CHRISPY's Avatar
shiftlight is a good thing
What cam specs did you go with? Where are you planning to tune?
cheers,
Chris
Old 04-16-2004, 08:11 AM
8 Sec Tuner
Mike TexaSS's Avatar
Also what intake manifold and throttle body and what other boltons and are there cats on the car?
Old 04-16-2004, 12:07 PM
KGSloan's Avatar
good to hear.
what are the cam specs?
i can't wait to see what it puts down.
shiftlights are wonderful things. i swear my tach says 5000rpms when i hit the rev limiter in first gear
Old 04-16-2004, 12:49 PM
c5blkvette's Avatar
I would like to see chassis dyno results with head swap ONLY (everything else the same and eg. a TR224 cam) between:
1. Standard LS1 heads
2. AFR heads
3. Stg II TEA or AS heads (or perhaps you could do a reputable non-sponsor)
Tony, this would be a big selling point if your heads really do perform better. and I am sure that a few gaskets arent all that expensive.
Old 04-16-2004, 02:05 PM
SSU Moderator
RyanJ's Avatar
so the cnc'd 205's, fast 78mm intake, and a 224/228?
Old 04-16-2004, 10:36 PM
ssvincels1's Avatar
yyyyyyyaaaaaaahhhhhhhh!!!
now i'm "Patiently" waiting for those #'s, lol.
Old 04-16-2004, 10:49 PM
C_Williams's Avatar
..... 450 RWHP / 410 RWT posted on the corvette forum...
Old 04-16-2004, 11:01 PM
ssvincels1's Avatar
thank you
Old 04-17-2004, 12:33 AM
Got Me SOM's Avatar
great numbers, sounds like those afr's really rock. When I'm ready I'm gonna purchase a set for my blower setup. Do you recommend the 205's or 225's?
regards,
Jeff
Old 04-17-2004, 08:31 AM
JBsC5's Avatar
I read somewhere that the comp XER cam specs were 224/228 .581.
AA Andy in california did the tuning..
450rwhp and 410 tq after tune
Old 04-17-2004, 12:53 PM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
I'm really sick of all this teasing. Are the heads for sale yet?!!!!!!
When and where?! Stop messin' with us. Really. I've never seen so much messin' with the consumer before. If they're good, I'll buy them already. Yeesh.
Old 04-17-2004, 02:25 PM
Chuck@'s Avatar
All us retailers have our initial orders in, and expect delivery within a 3-4 weeks. Afterwhich we at HPE will begin our R&D program as I'm sure most everybody else will. I expect some very serious numbers out of them...
Chuck
Old 04-17-2004, 04:03 PM
Spinmonster's Avatar
or the end of these silly 'they're-gonna-be-the-greatest' posts if we get similar results like the LT1-afr results. They were the most talked about till that flop ended with leaks and same old performance.
Ever see so much hype before an actual install?
450 with a 224/228 cam has been creamed years ago.
Old 04-17-2004, 04:12 PM
30th TA 0219's Avatar
Well, what I don't get is why he posts over on CF all the time. Well, actually, it's cuz they are more impressed with peak numbers, and if 't new and expensive, IT MUST BE GOOD.
How about some times? Who really gives a **** about peak numbers, and why did Tony start the post here, but hasn't put any numbers yet?
I really want to like these, but the AFR LT1s are a huge disappointment, and this has the makings of that.
Please Tony dispel everything I have said here, I really want you to!
Old 04-17-2004, 04:14 PM
!LS1 11 Second Club
Chuck
"Expected delivery" has been 3-4 weeks since forever.
Old 04-17-2004, 04:18 PM
JBsC5's Avatar
The best I can tell from the graphs:
hp/hp tq/tq
3000 rpms 180/190 320/330
3500 rpms 220/240 330/350
4000 rpms 250/290 340/380
4500 rpms 300/340 340/400
5000 rpms 320/390 340/410
5500 rpms 340/420 320/400
6000 rpms 320/440 280/390
6500 rpms. 310/450 250/360
Old 04-17-2004, 04:19 PM
Chuck@'s Avatar
Yeah, but the difference is now they have our money
Later,
Chuck
Old 04-17-2004, 04:40 PM
masterdill's Avatar
Go to a track and get some slips and scan/post them ASAP... or maybe you did already and were disappointed.
Old 04-17-2004, 04:41 PM
got_hp?'s Avatar
that was with unported afr's.........id expert quality ported afr's to go well over 500rw on stock bottom ends.
Quick Reply: AFR 205's "Maiden Voyage"....
