Setting up a Gbody Suspension...
I'm working on setting up the Suspension in my SS..for drag purposes.
Front has Eibach Springs which dropped it about 2", and Lakewood 90/10 Shocks.
Rear is UMI Adjustable Upper CA's and Boxed Lower CA's with a 1" Solid Sway Bar. It also has Eibach 2" Drop Springs and Bilstein Shocks. That is a handling suspension and very stiff so I'm trying to change it up for drag.
I'm looking at these here..
http://www.summitracing.com/parts/cee-2720/overview
I'm trying to figure out if I need to raise the back up with a taller Coil Spring to get it to properly weight transfer..any advice?
