SPUN A BEARING !!!!! 383 or lq9
hey guys motor didnt las as long as i thought it would i had a problem before hydro locked the motor and had a ton of fuel in the oil now i flushed the motor with oil a couple time and thought id be fine lasted 2 weeks on the street and one track night motor pulled fine went 7.4 93 mph on motor and not too good grip
now if this would have been a couple years back id go with lq9 when they where a dime a dozen but they have gone up on price the cheapest i have found has been 1200 long block what do u guys think i couple do im looking at a 1500 budjet for the bottom end and id like to get the most i could out of it
383 or 364??
looking to spray about 300 or more
383 or 364??
or should i make the 347 just forge the rods and pistons and hit it with big bottle need some help here guys kinda running out of potions here because of the money issue
Kinda just went through this myself. I talked to TEC in Riveria Beach and to forge my ls1 was going to cost in the 3k range. Between rods, pistions, machine work, etc... It adds up quick. I also thought about a 6.0 but unless I was going to put a set of heads on it and build it it wasnt worth it to me considering 6.0s have gone up in price and the added weight. Luckily I found a stock bottom end ls1 with 32k miles for 800 bucks. It was very clean and for my 150 shot would work just fine. Good luck and post some pics when you get it done
put up half the money for the 6.0 already. i was looking for the stuff and came to conclusion that it was way out of my budget. so went and got the 6.0 long block for 1000 I'm going to add my heads and cam from the ls1 and call it a day. hope to make 450 to 470 hp and hit it with 150 200 shot. save some cash and make it a 408.
You sound like you are on the right track now.. I'm not sure what cam you had, but it will probably be a little more mild in the bigger engine, but the heads should wake up nicely with the larger bore size. And now you got a good platform for a later build.
good luck
good luck
that what im hoping for. i gotta bust my cuzins ***** with his cobra he running 6 and teens. i went all last year on this build had lots of trans issues and finally got it right. but motor didn't last one track night. i had washed out bearings and still went out. now it just got me to a 6l with more possibilities.
those heads should put me some were in the 10.8:1 cr to about 11:1 cr right? how much bottle can i run threw this set up and what fuel to use in the nitrous dedicated system?
yea that's what i was thinking. i was thinking about milling more but im not sure with the ms3 if i come to clearance issue. so i think im just going to clean em up and put them back.
http://hyperfuels.com/find-a-dealer/#TX
Here is some info about the fuel.
http://hyperfuels.com/race-fuels/urt-advanced/
Blow By racing in Boca raton. Fl carries it and they aren't too far from you.
www.blowbyracing.com
