WS6 shifting problem
Old 01-15-2013, 11:17 PM
andrewsem's Avatar
Default WS6 shifting problem
If I drive to about 10 miles per hour and then try and shift into second gear, the shifter will not engage into second gear, it will go straight into 4th unless I speed up a little bit. Has anyone else ever had this problem?
Old 01-15-2013, 11:22 PM
Zlow28's Avatar
look into "skip shift"
it can be deactivated
Old 01-17-2013, 03:11 AM
Kingman's Avatar
When the car is under 35% of WOT in first gear and is gaining speed the Skip shift feature like he said above kicks in and makes you go from first to fourth.
Quick Reply: WS6 shifting problem
