Stock Crank or Forged
Well my crank can't be salvaged due to some spun rod bearings. The question is, do i spend a couple hundred on a used stock crank and have it machined or (Machine shop said they can get me a stock crank and have it turned for a total of $300-$400 ) or do i spring for a forged stock stroke crank for around $800. LS1 block, Eventually going with AFR heads for the ability to push 25psi but itll have 317s for now. the rest of the drive train will be good for what ever i want to throw at it (jakes 4l80 and fab 9") the weak links are currently a stock crank and an LS1 block. Can the block even take more than a stock crank can?
Call Callie's, ask them if they have a 3.825 forged crank on the shelf that just needs finishing.
They have them.
They cost $660.00 + shipping
I called a few months ago and they had it shipped out the door in 6 days.
In my research......you're not gonna make 25psi, or at least not reliably and multiple times, with a 4 bolt block and heads. So.........
They have them.
They have them.
They have them.
Wow......I'm glad I asked. I'm also going higher than normal on the compression and also using full time E85. Heavy tranny too (4L80E).
I'll be at 10.3:1 cr.
Were you using a 4 bolt per cylinder set up?
What heads and gaskets?
What kind of head studs?
I'm planning to shoot for 18psi with twins.......hope I break the 1,000 RWHP mark through my 4L80E.
I think that ill stick with a stock crank if i can find one. it seems like the crank and the block have the about the same limits. Not really shooting for 1k rwhp although it would be bad ***.
They have them.
They have them.
Smart move. The K1 Technologies cranks look good to the naked eye, might want to check them out.
25lbs of boost out of what Turbo/Blower? Its going to be different for every combo. Keep the cylinder pressure and IATs low and let er' rip.
The stock crank won't limit you. I would how ever get a Iron 4.8/5.3L block and have it bored to 347 specs.
