Has anyone maxed out an ebay gt45?
Old 01-16-2013, 06:44 PM
b20forlife's Avatar
Default Has anyone maxed out an ebay gt45?
im looking to see if anyone has maxed one out? i want to buy one just want to make sure i can reach my goal of 650whp on pump
engine specs
5.3
tu1 cam
918 springs
arp head studs
katech rod bolts
ls9 headgasket
edelbrok PRO-FLO XT intake
90mm tb
th400
80lbs injectors
looking for 9s in my mustang notch
Old 01-16-2013, 07:14 PM
95bowtie's Avatar
I would say that is the max. Dont see any reason why you couldnt reach your goal.
Theres been a handful of ppl that have made that much power with that turbo already.
Old 01-16-2013, 07:36 PM
jridenour31's Avatar
May not make 650hp but it is definitely capable of 9's.
Old 01-16-2013, 08:17 PM
turbocamaro125's Avatar
Ask denmah...he will know the limits of the turbo
Old 01-16-2013, 08:18 PM
a4ls2goat's Avatar
I trapped 135mph in my 4000lb gto. With a 4.8. Ont the gt45
Old 01-16-2013, 08:38 PM
Moderator
denmah's Avatar
my friends truck went 126.
4700lb truck.
10.80s i dont think 9s will be hard in a notch
Old 01-16-2013, 09:07 PM
LS1NOVA's Avatar
I dont think 650w is max. I bet you could make 750 or a little more.
Old 01-16-2013, 09:29 PM
831jd's Avatar
I have the same setup but a locked 4l80e and e85 how much you guys think ill be making on 18psi on 706 heads though... Ill be tuning it in a few weeks
Old 01-16-2013, 09:55 PM
Theblacknightls1's Avatar
What type of Dyno did you make 580whp
Old 01-16-2013, 10:03 PM
a4ls2goat's Avatar
Dyno jet. This was through a unlocked converter. And running a little lean.
Old 01-16-2013, 11:57 PM
831jd's Avatar
Was that on 16psi?
Old 01-17-2013, 12:55 AM
6point7s14's Avatar
Oneoverwrx went 147 I think in his 240 with 4.8 gt45... I should have some passes with mine soon as well
Old 01-17-2013, 12:56 AM
Moderator
denmah's Avatar
our truck did 607rwhp on 17psi, that was a 4.8l also haha
Quick Reply: Has anyone maxed out an ebay gt45?
