Need Help Fixing Sway Bar Mount
Old 01-17-2013, 12:14 AM
ls1z01's Avatar
Default Need Help Fixing Sway Bar Mount
Any suggestion on fixing my frame to mount my sway bar back on? It torn off from the frame and the factory nut was ripped off.
Thanks in advanced!
Attached Thumbnails Need Help Fixing Sway Bar Mount-20130105_105514.jpg   Need Help Fixing Sway Bar Mount-20130105_121411.jpg
Old 01-17-2013, 06:45 AM
Grimes's Avatar
I would just get someone to weld in a patch there. Did the frame get bent at all from what happened?
Old 01-17-2013, 11:13 AM
ls1z01's Avatar
Yeah I was thinking of just welding the bracket back on for a permanent fix and since only the bottom hole / nut was ripped off I can still get the bracket in place with the top hole. I used the ADDCO sway bar and they had their own bracket with one hole mount. After my rear bump stop worn out going up and down my drive way was enough to rip off the nut from the frame itself.
Quick Reply: Need Help Fixing Sway Bar Mount
