OBDII to OBD1... does the ecm need to be vin matched? Tunercat questions.
Old 01-19-2013, 07:34 AM
VandykeT/A's Avatar
Default OBDII to OBD1... does the ecm need to be vin matched? Tunercat questions.
From what I understand in order to do the OBDII to OBDI conversion (97 Z28) I need a ecm from a 94-95 model and a resistor for the knock sensor. Well on ebay I see ecms set to your vin number for sale but since the car is a 97 will giving them a 97 vin still work? Do I even need it vin matched? Can I just pull a ecm out of a 95 M6 car and stick it in? Also this is for a friend of mine and hes looking at using Tunercat and learning to tune. For those that have used tunercat how difficult is it to use? Same idea as HPtuners or is it a little more simple. Thanks
Old 01-19-2013, 07:53 AM
Village Troll
SS RRR's Avatar
You can use a resistor, but you can also just keep it plug/play and go with a OBDI knock sensor. You do not need a vin matched PCM, however if you have emissions concerns you will fail before you roll your car in for a test since OBDII emissions is tested through the data port and whether or not OBDII applies is done through the VIN on the vehicle. They try to test your car it will come back with a no communication type error.
Old 01-19-2013, 08:29 AM
VandykeT/A's Avatar
We don't have any kind of emissions testing here. They just check the lights and shake a wheel. Is the obdI knock sensor the same connector as the obdII or will I need the connector to?
Old 01-19-2013, 08:39 AM
Village Troll
SS RRR's Avatar
Nope. It's the same. Good luck.
Old 01-19-2013, 09:16 AM
9-Second Club
Ed Wright's Avatar
There isn't really any good reason to put an OBD1 PCM in it. Tunercat has OBD2 software also. Very easy to use. There is absolutely no advantage to an OBD1 PCM. As said, the vin doesn't matter.
Old 01-19-2013, 12:00 PM
VandykeT/A's Avatar
I thought the only OBDII software was the JET system and I seen that it was around 500 bucks and you had to buy another software in order to log it. If Tunercat makes software to tune the 97 ecm the same as it would the 95 then thats what I'll do. I'll look into it. Thanks
Old 01-19-2013, 01:55 PM
96capricemgr's Avatar
I thought Tunercat sold the OBD2 LT1 editor to JET who then wattered it down and jacked the price.
If Tunercat still offers OBD2 software I would seriously look at that Tunercat is good to deal with. When I did the OBD1 swap LT1 Edit for OBD2 was still in testing and not released and LT1 Edit sucked support wise so I bought tunercat and went OBD1 but that was a long time ago and you do have more options now.
Old 01-19-2013, 02:12 PM
9-Second Club
Ed Wright's Avatar
OBD2 Tunercat covers about everything through the new Camaros. I use it for all LSX through 2004, and through 2006 for trucks. He did Jet's software, but never sold anything out to them.
Old 01-20-2013, 07:17 AM
That is good news I have an 05 truck I wanted to buy software for.
Old 01-20-2013, 02:19 PM
http://www.tunercat.com/tnr_desc/jetlicense.html
Old 01-20-2013, 03:43 PM
speed_demon24's Avatar
Originally Posted by 96capricemgr
Not a bad price from amazon.
http://www.amazon.com/14005-Dynamic-.../dp/B0018CWGS8
Old 01-20-2013, 04:09 PM
I just cringe at the thought of spending a dime with JET though they sell so much junk I wouldn't want to pay them for retailing someone else's good product.
Old 01-20-2013, 10:02 PM
cardo0's Avatar
Default Anyone try Howell EFI?
Howell specializes in EFI conversions: http://howellefi.com/. I did find one of the Howells was a development engineer for GM. But i never read anyone using Howell for mail order tunes.
cardo
Old 01-21-2013, 05:22 AM
A local used Howell for some work on a blower b-body wagon and I only met the guy once but his result combined with what he paid them and such I wouldn't be trying them out.
Quick Reply: OBDII to OBD1... does the ecm need to be vin matched? Tunercat questions.
